Shift Linkage Needed!
Old Apr 23, 2004 | 07:09 AM
jtmulreed's Avatar
jtmulreed
Exclamation Shift Linkage Needed!
(This is also post in the Trans. Section)
I am looking for the ENTIRE automatic transmission shift linkage (from the end of the column shaft to the trans casing, including all brackets) for a 1990 F150 4X4 with a 302/AOD combination. I just picked this truck up, and believe it or not, most of the linkage is rusted past the point that sandblasting will help! Needless to say it is VERY hard to shift and I'm sure it's not helping the TV cable adjusment/trans any.
I've tried local boneyards and had no luck, and I would really rather not spend a ton of $$$$$ at the dealer.
If anyone has a source that ships to CT, or has one they would be willing to part with, please let me know.
Thanks in advance for the help!
