ruff idle
Old Apr 22, 2004 | 12:26 PM
greenterror's Avatar
greenterror
Question ruff idle
it fluctuates between 1000 rpm and zero and stalls.it was fine then i cleaned my air filter from my k&n fipk,then this started any suggestions
Old Apr 22, 2004 | 02:23 PM
CobraXP's Avatar
CobraXP
If you put too much oil on the K&N, some of it has probably gotten on the mass air sensor and has coated it. I would try cleaning it and the IAC. That will probably fix the problem...
Old Apr 22, 2004 | 06:44 PM
greenterror
Another quick question - you mentioned something called the IAC and cleaning that. What does IAC stand for?
Thanks
Old Apr 22, 2004 | 07:40 PM
Blly177's Avatar
Blly177
idle air control valve
Zip
British Columbia
Jan 17, 2008 10:45 PM
rgiles
Oil & Lubrication
Jan 16, 2003 07:27 PM
my79bronco
Jul 9, 2002 07:08 AM
Ken00
1983 - 2012 Ranger & B-Series
Feb 4, 2002 10:38 PM
