An Electrical Mystery??
Old Apr 22, 2004 | 12:10 PM
MercuryM100's Avatar
MercuryM100
I haven't had any problems with my truck's (66 Merc100) electrical system...until yesterday that is!
I started her up and the headlights and tails came on fine...but the turn signals, heater, wipers would not work. Then...after about five minutes of idling they came back to life! I started her up today...and the same thing happened!
The only thing I've changed this week has been the addition of a washer pump...but I used the existing wiring. Could it be that I didn't ground the pump correctly?
If so, then why would everything come back to life after it's idled for a while?
Thanks for the help!
Chad
Old Apr 22, 2004 | 12:40 PM
banjopicker66's Avatar
banjopicker66
I bet you disturbed some wiring or connectors in there.
Lights are on a separate circuit from the keyed ignition switch, but everything else you mentioned routes through the switch.
From the description, it sounds like you need to check the power supply wiring to the ignition switch wiring harness, and/or the fuse box.
It is usually easier to inspect the wiring with the gauges removed.
Old Apr 22, 2004 | 01:07 PM
MercuryM100
banjopicker66 (love that avatar!) I didn't go near the ignition, or any of the connectors under the dash....I actually used the wire from the previous pump.
Is it possible that I did not ground the pump and it's affecting the system...I attached the ground wire of the pump to the inside fender well.
Old Apr 22, 2004 | 04:44 PM
302or5.0 and more's Avatar
302or5.0 and more
you have a bad ground witch one i don't know but it is using your lighting ground as a sorce of ground, backfeeding, This can burn up wireing becareful, a lose connection can get hot and then work for awhile this is called arkwelding
Old Apr 22, 2004 | 05:11 PM
banjopicker66
Glad you like the avatar.
Rethinking your situation, I have to correct myself a bit. It looks like you are getting power TO the ignition switch - as indicated by the engine starting and runnning.
Looks like the other power feeds may be a problem. I would carefully go through the fuse box, check for loose fuses, rusted fuse contacts, loose wires, etc. If you have any circuit breakers, check them as well for continuity when cool.
I'll check my '66 for any more ideas.
Also, the earlier post about a bad ground is well made. I doubt that installing the ground for the pump did anything, though,
I still think you disturbed something in there, such as a ground about to go bad.
Old Apr 22, 2004 | 07:50 PM
ol yeller's Avatar
ol yeller
Yep
My ol 66 did that and the brake wire on the master cylinder had come loose. Signals seem to go on the same wiring. Once the lights wouldn't work and it was the dimmer switch. Good luck.
Dave
Old Apr 23, 2004 | 06:20 AM
William's Avatar
William
Bulkhead connector! Pull it. clean the crud off it and use plenty of dielectric grease when you put it back together.
Y2KW57
59
Jan 29, 2017 01:44 PM
ssummerangel3
Jul 27, 2015 05:27 PM
ng19delta
17
Mar 30, 2015 10:27 PM
WBCody
Sep 1, 2010 10:30 AM
TheMonkey
Feb 4, 2009 06:04 AM
