C6 Jerking
Old Apr 22, 2004 | 10:43 AM
Smokey0210's Avatar
Smokey0210
Exclamation C6 Jerking
OKAY, SO I HAVE THIS 1988 151,000 F-150 WITH A 4.9 AND A C6. WHEN DRIVING IF I GIVE IT MODERATE GAS THE VEH WILL JERKING BETWEEN 2 AND 3 GEAR LIKE IT CANNOT MAKE UP ITS MIND. WHEN IT IS LOCK DOWN IN A GEAR THERE IS NO SLIPPING AND TRANS RUNS STRONG. WHEN IT IS DOING THIS IF I PRESS THE GAS HARD IT WILL LOCK IN GEAR AND TAKE OFF AND IF I LET OFF THEN GIVE IT GAS IT WILL STOP ALSO.
WHAT DO I NEED? A NEW TRANS? VAC LEAK?
SOMEBODY HELP PLEASE!
JORDAN
Old Apr 23, 2004 | 12:48 AM
FordPickup460's Avatar
FordPickup460
It would be more easy to read your post if it was in lower case, not all caps. Check your transmission fluid level, and check the modulator.
Old Apr 23, 2004 | 06:45 AM
Smokey0210's Avatar
Smokey0210
tried the fluid, but wheres the modulator
Sorry about the caps but I leave it on for work and forgot to turn it off. What should I look for on the modulator when I find it?
Any help is appreciated
Jordan
