1978 - 1996 Big Bronco
25-50 mph vibration
Old Apr 22, 2004 | 12:50 AM
txbronco's Avatar
txbronco
25-50 mph vibration
I have a vibration only when I accelerate between 25 and 50 mph anything above or below runs smooth or if I take my foot off the gas it immediatly goes away? Does anybody have an idea my tranny maybe I have no clue and I want to take it to a shop just wondering which shop?????
Old Apr 22, 2004 | 01:35 AM
broncobillybob's Avatar
broncobillybob
It's all the horses in full gallop...nah j/k. What type of vibration? Heavy, medium or lite. My tranny unusually vibrated at interstate speeds (65-75) and eventually had it replaced when it worsened. It was a heavy vibration and was accompanied by an equally strange noise. It was the torque converter, dunno if this is your deal but it's a start. Good luck. -Triple B
Old Apr 22, 2004 | 05:01 PM
abigor060's Avatar
abigor060
i just had something similar..my bronco had a vibration between about 50-60mph when i let my foot on or off the gas. everyone i talked to said the tranny or the torque converter. after much searching on the forums and under the truck i found out it was a u-joint on the rear driveshaft that was completely shot. cost me about $20. totally solved the problem and it drives great. might be worth checkin out...
Old Apr 22, 2004 | 05:31 PM
txbronco's Avatar
txbronco
The rear u-joint was hammered changing it and hoping it solves the poroblem I will keep you guys posted.
Thanks
Old Apr 22, 2004 | 07:23 PM
Superman_ManOfSteel's Avatar
Superman_ManOfSteel
hey , u might want to check your bolts on the driveshaft. I was having a vibration at about the same speed...one of my bolts on the driveshaft had wiggled out and another was 3/4 of the way out. Hope this helps.
Old Apr 22, 2004 | 10:25 PM
txbronco's Avatar
txbronco
It was the rear u joint.
