Sponsored by: Real Truck
New brake lines
Old Apr 21, 2004 | 08:39 PM
stealth1's Avatar
stealth1
New brake lines
With a pro comp 4" lift will I need longer brake lines? The stock ones look as if there long enough. I don't want to wait until my truck is tore apart to find this out.
Old Apr 21, 2004 | 09:06 PM
Yeti's Avatar
Yeti
No you definetly don't nee longer ones with only a 4" lift.
You can run a 8" without longer ones.
Ususally, you just have to drill a hole and relocate the bracket.
Old Apr 21, 2004 | 09:35 PM
stealth1's Avatar
stealth1
Thanks alot for the info. I did not think about moving the bracket... On a different note I got the pro comp lift and it came with the ES9000 shocks instead of the ES3000 are the 9's any better or do I need to just go with bilstiens?? I read on here that the 3000's are poop.
Old Apr 21, 2004 | 09:43 PM
Yeti's Avatar
Yeti
Can't help you on that one, I have never ran pro comps.
alchemist1
Sep 28, 2012 06:48 AM
oldbird1965
Sep 28, 2011 06:01 AM
halltm
May 31, 2011 11:33 PM
midcal48
Feb 12, 2011 07:41 AM
Epd444
1983 - 2012 Ranger & B-Series
Oct 31, 2007 07:16 PM
