Wiring help PLEASE???
Old Apr 21, 2004 | 08:02 PM
zieg96's Avatar
zieg96
Question Wiring help PLEASE???
I have a 1990 and 1991 F-150's that I need to know what color wires to power up the fuel pump to drain the tanks. The 1990 has bad gas in both tanks that need to be pumped out. The wiring is toast so I am replacing it all from the 1991 truck. I want to use the wiring plug that feeds the gas tank to power up. Thanks in advance for the help.
Old Apr 22, 2004 | 06:35 PM
bobcf's Avatar
bobcf
chilton says red is + and ornge is - on the front tank. brown with white stripe is + and ornge is - on rear tank.
Bob
Old Apr 22, 2004 | 10:08 PM
zieg96's Avatar
zieg96
Thank you very much.
Old Jun 2, 2004 | 02:19 AM
sigginsbuilders's Avatar
sigginsbuilders
If your truck is a california truck just make sure that you got the right motor. Chilton doesn't cover those very well. my 1990 f350 is a mix and match. book isn't very accurate
