Instrument Cluster
Old Apr 21, 2004 | 01:06 PM
evin's Avatar
evin
Instrument Cluster
I have an 86 f150 my speedometer or gas guage dont work on the front or rear tank.someone on this site told me to start with the speedo cable It did not change I guess its something more serious could my whole instrument cluster be bad If so where can I get one?
Old Apr 21, 2004 | 01:07 PM
evin's Avatar
evin
P.s thanks for all the help yall have given me to get this truck on the road.
Old Apr 21, 2004 | 01:15 PM
trotsky's Avatar
trotsky
Evin, before you replace your instrument cluster, check to see if the gear in the transfer case is bad that connects the speedo cable. I'm assuming you've already checked the plastic gear at the end of the speedo where it connects to the transfer case. My speedo cable was fine, just need to replace gear in transfer case. Good luck.
Old Apr 21, 2004 | 04:25 PM
nickmobile67's Avatar
nickmobile67
They must be two seperate problems. The gas guage is electric, and the speedo is mechanical. Check the cable for the speedo. As far as the gas, if it dosn't work for either tank the problem is probably not in the tanks. Start from the guage and work back. Check for good grounds, shorted wires, ect..
Old Apr 22, 2004 | 10:05 AM
evin's Avatar
evin
how hard is it to change the gear in the transfer case and if the gas guage is electric could it be a fuse since my horn dont work either?
ponyman_65
Oct 2, 2014 08:07 AM
RIKIL
24
Mar 9, 2013 03:50 PM
COLMISS
Nov 21, 2008 08:25 PM
hush210
1997 - 2003 F150
Feb 23, 2007 08:37 PM
Fordtrk26
Nov 4, 2003 10:32 PM
