gas filler problem
Old Apr 21, 2004 | 09:12 AM
wrenchturner's Avatar
wrenchturner
gas filler problem
I recently picked up a 81 f150 4wd with a 300, and 4spd,4wd for 700 bucks. it has it's issues and i'm working them as i go but i hate putting gas in it. it takes forever to fill i have to put it in so slow or it spills out. is this a common problem, or is it my problem. I came without a gas cap and i really dont want to drop the tank(19 gallon side) and check for a lost rag down there, but is there anything else i can do?
Old Apr 22, 2004 | 02:16 AM
Superdave's Avatar
Superdave
It seems to be a somewhat common problem for some reason.
Old Apr 22, 2004 | 06:18 AM
F150Steve's Avatar
F150Steve
I have the same problem with my '86. Seems likes it takes hours to fill up.
Old Apr 25, 2004 | 08:11 AM
Scott Fraser's Avatar
Scott Fraser
Takes me forever! But it's a small price to pay to drive a great truck.
Old Apr 25, 2004 | 07:40 PM
thisspaceleftblank's Avatar
thisspaceleftblank
I replaced the tank on my F150 with a plastic one, I believe it didn't have an opening for a hose that connected high on the filler neck, I assume an air return, and now I get the same problem with it only filling slow. Oh, rust in the tank was causing a drive, jerk, drive, jerk problem... filter on gas tube was clogging then rinsing off with the motion of the gas...
Old Apr 26, 2004 | 05:35 AM
Beast12's Avatar
Beast12
I have the same thing with my truck. I know the previous owner replaced the tank about 2 years ago. When I look in the filler neck, it looks like there is no inner tube in the big hose. Oh well, slow and steady wins the race!
-Matt
Old May 14, 2004 | 06:39 PM
Lee Lichterman's Avatar
Lee Lichterman
In your filler neck, there is supposed to be a black plastic tube that is wedged in the upper half of the filler neck, above where the gas nozzle fits when you are filling it to let the air out while filling. If it is missing, you get what you are describing.
I know, I swapped the in tank fuel pump and forgot to put it back in and figured it wouldn't hurt anything. After 2 slow fill ups, I yanked the fille rtube out, put it back in and now I can pump full speed again.
Mine was slightly chewed up and I looked all over for a new one and couldn't find it so not sure how you can replace it. Junk yard, dealer item? It is about half an inch in diameter and has that flexible ring stuff on it so it can make the bends like a cheap gas can has. I don't know if a piece of rubber fuel line would work or not. It needs to wedge itself in there so it doesn't fall in teh tank so not sure I would experiment too much. Might be worth the price to get a new one. I was able to drop my fille rtube just by loosening the tank and fighting it out and didn't have to drop the tank all the way down.
Good Luck,
Lee
86 F-150 XLT 302 EFI
Old May 15, 2004 | 05:15 AM
srercrcr's Avatar
srercrcr
I bought my 83 brand new, never experienced slow fill-up. I can go full speed on the pump handle. Worst I've had is the angle of the spout is off, it will kick off.
I'd check out that vent tube idea. Keep on truckin'.
