352?
Old Apr 21, 2004 | 08:57 AM
swampo's Avatar
swampo
352?
Hey guys I have a little bit more than stock 352 and last nite i picked up a 4 barrel intake from a junkyard and I was wondering If doing this was worth it. I am not really looking for huge power but want to have a good performing engine and keep reliability. O and I currently have a 2 barrel holley.
I was also concidering putting on some headers that I got from a buddy for free. I have been looking at going to a petronix ignition setup or a Dui type dizzy which one of these would give me best performance for the money any help would be cool thanks
Old Apr 21, 2004 | 09:39 AM
skinsey's Avatar
skinsey
I have the cast iron 4 bbl intake and hooker headers on my 352 and I think there is a considerable HP gain, more air in and out of the motor. However you are very limited on flow from stock cast iron heads.
Old Apr 21, 2004 | 09:59 AM
Mike G's Avatar
Mike G
Sounds like a good low-buck hop up in the makings. You already have the manifold, the headers are free, a used 600 Holley is about $40 and you should be set. Go with the Pertronix, it will save you $200+ over the DUI. If I remember correctly, the stock heads on the 352 are more of a performance head with smaller chambers, they will handle plenty of HP with no problem.
Have fun --Mike
Old Apr 21, 2004 | 10:03 AM
skinsey's Avatar
skinsey
Dont forget the Nitrous. Runs great on mine......
Old Apr 21, 2004 | 01:33 PM
original67's Avatar
original67
What type of nitrous set up did you use, I am thinking about running nitrous on my 352 maybe just a 100 shot or less because i dont have forged pistons or crank, I have a 67 f-100, the motor is 352 bored.060, it has ported heads, and soon to have the crane 343901 camshaft, with long tube headers, and dual 2.5" exhaust, with a 500cfm 2 barrel is there a nitrous set up i can get for that
Old Apr 21, 2004 | 01:38 PM
swampo's Avatar
swampo
Would any of you guys do anything different or do you have any sugestions on other stuff I should do while im at it or anything else I should add to my build
Old Apr 21, 2004 | 02:48 PM
swampo's Avatar
swampo
son of a mother I was just workin on cleanin up my buddies headers and I found some tiny pin holes in one of the down tubes this is not cool. so now my ? is weather or not the stock manifold will flow well enough with a 600 cfm carb or should i find another set of headers i have a feeling you guys will tell me to get some headers so what kind should i get that will match up well with stock heads.
Old Apr 21, 2004 | 04:58 PM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
If its just the one tube with pin holes in it...depending on it doesnt look it was shot with a shot gun?
Take it to your local welder and have him fabricate a sleeve for that one! weld it up and go! Good Luck..Russ
BTW..I use to do this all the time with my dirt bikes!
Old Apr 21, 2004 | 06:51 PM
skinsey's Avatar
skinsey
150 shot. NOS Sniper system.
Old Apr 21, 2004 | 07:03 PM
skinsey's Avatar
skinsey
I have been running this system for months now (a 10lb. bottle every 2 weeks on average), on stock crank and cast pistons. You would need a four barrel for it unless you want them to make you a special 2 barrel plate. Some would say I am crazy on a stock motor but the FE will handle a 150 shot no problem. Above 150 I would be a little worried. Look at the second set of pics I have, particularly the last one.....that was in second gear from a dead stop I hit the switch as I nailed the throttle....and yes it has a locker in the rear spinning 3.73 gears out too 295 50 15's. I got out of the bottle when it hit 3rd..... And yes it will go way into 3rd smokin the tires.
Mercmeister
38
Mar 27, 2022 11:45 PM
TEX001
34
Aug 9, 2020 07:44 AM
abc2129
Mar 28, 2011 07:23 PM
taylorjgreen
Aug 3, 2008 12:33 PM
fordman428
22
Nov 24, 2003 05:17 PM
