Differential Rebuild
Old Apr 21, 2004 | 08:55 AM
bradleyj's Avatar
bradleyj
I recently replaced all the front drive axle u-joints on my 93 full-size Bronco. One of the joints was completely shot, causing a clunking sound when I turned corners in 4WD. There was also a whirring sound when I drove straight at higher speeds (>20 mph) in 4WD. I figured that this also had to do with the failed u-joint. However, this noise is still happening even after I've replaced all the u-joints. I'm thinking it's the front carrier bearing. I need to remove the hubs and spindles again anyway to install the new dust shields I had to order, so I'm thinking about buying a rebuild kit and rebuilding the differential. It's a Dana 44 IFS front axle. Is this a difficult job? How long should it take me? Do I need special tools? Any tips?
Old Apr 21, 2004 | 09:29 AM
Sycostang67's Avatar
Sycostang67
From what I understand, rebuilding them is fairly easy, but getting them setup correctly (clearances, and tooth contact) is the hard part, and requires special tools.
