First time buyer looking a buying 7.3 need some basic
knowledge as to general maintenance on this motor i.e. oil changes
type of oil used weight and manufacturer, best filters to
use oil and air, also being this a farm vehicle can I
use off road fuel to save on cost? Whatever knowledge
you which to give a 1st time diesel buyer
use oil and air, also being this a farm vechicle can I
you wish to give a 1st time diesel buyer
>changes
Oil changes depend alot on the driving conditions. Being this is a farm truck I'd change it every 3000 mi. (assuming you'll run conventional oil and won't be having it tested).
The owners manual calls for 15w-40 with a CH-4 rating (Shell Rotella-T, Chevron Delo 400, etc.) The oil filter on Superduties is a Motorcraft FL-1995.
The stock paper air filters seem to do just fine. I run a K&N in a modified airbox.
Change the fuel filter at least every 15000.
As far as I know it is illegal to run dyed fuel in any vehicle licenced for highway use.
My '95 takes 14 qts to change oil. I don't know if that changed on the Superduties, but I don't think so. The cheapest place I've found to buy oil is Costco, where you can get a box of (6) 1 gal jugs for $32.99. You can get Purolator filters at Sears for $2.99. The cost of doing an oil change is about $23. Knowing it was done right, pricless.
GM - My 99 PSD uses 16 quarts per oil change (with filter change). As for Oil, I recommend Rotella 15w-40. I've used it in my 6.5 Chevy (don't shoot, I have a Ford now) I ran it 185K and it was still going strong when I got my Ford. I change every 5K miles. As for Farm Diesel, never! Unless you have a huge farm and it will never see highway use. The difference in price is road tax. Which I am happy to pay for good roads to drive on.
