1978 - 1996 Big Bronco
New Member, old problem
Old Apr 20, 2004 | 09:54 PM
mudbuggy
Guest
Posts: n/a
Question New Member, old problem
Hi, just joined after searching around message boards and believing this one has the most positive feedbcak around. Anyway, my 91 Bronco has the dreaded Check Engine Light coming on intermittently while driving. Seems to be OK when cold, but as she warms up the light comes on, goes off, comes back on. Exhaust smells. I think it smells like ammonia, friends say rotten eggs. Running rich.??
I replaced the HO2 sensor, did the tune up with plugs, wires, cap & rotor, fuel filter. Don't have a code reader and Ford wants $200 to plug it in. If anyone has some do-it-yourself suggestions, I'd appreciate it.
91 Bronco 302ci/5.0L
Headman Headers
Magnaflow ceramic muffler, twined after CAT
Original dual CAT's still in place
K&N FIPK
Hypertech Chip
Thanks
Old Apr 20, 2004 | 09:58 PM
RLKBOB's Avatar
RLKBOB
Did you disconnect the battery when you did all this? The computer needs to reset. You don't need a code reader check out www.fordfuelinjection.com and look at getting codes.
Old Apr 20, 2004 | 10:05 PM
mudbuggy
Guest
Posts: n/a
OOPPS. Forgot that part. Yeah, disconnected the battery, turned on the headlights for 10+ min. Total drain. (With the Hypertech Chip removed.) Re-connected the battery and went thru the "learning" procedure. Then, since the light kept coming on, re-installed the Hyperchip per instructions. Same symptoms. I'll go check out the link. Thanks
Old Apr 20, 2004 | 11:03 PM
DW2455's Avatar
DW2455
if your getting a very foul smell you may have a catalytic converter problem, DW
Old Apr 21, 2004 | 07:51 AM
OJ's96's Avatar
OJ's96
What he said....Cat is going bad....
Old Apr 21, 2004 | 08:54 AM
4xBroncoMF's Avatar
4xBroncoMF
agree
that famous rotton egg smell is the cats
Old Apr 21, 2004 | 11:21 AM
Texas Ex's Avatar
Texas Ex
You can go to Autozone and pick up a code reader for about $25 or they should be able to pull the codes for you for free.
The reader is easy to use. If a newb like me can use it, anyone can.
