6 lug Ford?
Old Apr 20, 2004 | 08:42 PM
3Mike6's Avatar
3Mike6
6 lug Ford?
Hi,
I'm trying to identify what kind of chassis I have.
It's a pretty straight frame and doesn't "dip" down until about where a cab would mount.
It has a kind of wide-ish 6 lug bolt pattern for the wheels...which are 17.5 inch steel. Leaf springs front and rear.
The rearend is full floating..ala 3/4 ton or 1-ton, but single wheels in the rear, not duals.
The pumpkin resembles a DANA 44, but larger...it does have 10 bolts holding the rear cover on.
Does this sound like a Ford setup? If so, what years might it be from?
Thanks.
Old Apr 21, 2004 | 11:02 AM
51dueller's Avatar
51dueller
You have a Dana 60. A pretty much bullet proof axle with it's 9 3/4 ring gear. Even stronger than a 9". You can get any gear ratio you want from 2.xx to 5.xx (x meaning numbers).
Old Apr 21, 2004 | 07:16 PM
3Mike6's Avatar
3Mike6
Thanks for the reply.
Any idea of the year range it may be?
Thanks again.
Old Apr 22, 2004 | 01:12 PM
51dueller's Avatar
51dueller
I know for sure they were used from '56 and up on the F-350. They may have been used on 53-56 F-350's. Sounds like you have a F-350 since the frames don't have a frame arch over the rear axle.
Old Apr 22, 2004 | 10:47 PM
3Mike6's Avatar
3Mike6
Cool, thanks for the reply.
36th Tom
1947 and Older Ford Trucks
Jun 12, 2013 09:42 PM
parkerparkerm
Mar 9, 2013 08:21 PM
raytasch
Oct 9, 2012 05:22 PM
raytasch
Oct 2, 2012 09:36 PM
Jeff3298
Sep 7, 2008 10:19 PM
