1978 - 1996 Big Bronco
Fuel Guage Backwards
Old Apr 20, 2004 | 08:40 PM
LDBRONCO's Avatar
LDBRONCO
I installed a fuel tank and sending unit from a 89 bronco into my 79 bronco (I needed a fuel injection tank due to an engine swap). The tank was an exact fit and the electric pump works fine. It appears that the sending unit is built backwards from the guage. the gauge reads full with low/no resistance to ground and empty with high resistance. The sending unit is the opposite. Can I just replace the sending unit? Where can I buy one? Can it be wired to work correctly?
