a/c clutch
Old Apr 20, 2004 | 08:18 PM
greenterror's Avatar
greenterror
Question a/c clutch
to install a electric fan i need to run a wire to a/c clutch where do i connect it? i also need to run a wire to the ignition where do i connect this?
Old Apr 21, 2004 | 06:48 PM
Ultramagdan's Avatar
Ultramagdan
Hey greenterror, have you figured it out yet? What type of vehicle are we working on?
You need to find the wire that goes to the compressor that becomes hot when you select defrost. You will need a voltage testor or test light at least to see which line provides the current to it. Your line to the ignition will probably be to your fuse box.
