normal idle speeds????
Old Apr 20, 2004 | 05:43 PM
jon1221's Avatar
jon1221
just tuned my truck up and timed it to 10 degrees btdc and now it idles at about 800-900. is that normal? seems kinda high. i just replaced and adjusted the IAC and TPS as well as coil, wires, plugs, cap and rotor. other than the high idle, truck runs like new. any words????
BTW: its a '91 302 efi etc
Old Apr 23, 2004 | 06:59 PM
ALSAIR's Avatar
ALSAIR
There is a sticker under the hood, either on the air box (air filter box) or on the bottom side of the hood facing you. The sticker will have a vaccum diagram on it. Read that sticker and it will tell ya what your idle R.P.M's should be.
Al
Old Apr 26, 2004 | 08:34 PM
jon1221's Avatar
jon1221
Thanks Al, ill go look for it.
