air conditioner
Old Apr 20, 2004 | 10:51 AM
triggerjoe's Avatar
triggerjoe
air conditioner
Whats it gonna cost me to put in an air conditioner in my 1979 f100
Old Apr 20, 2004 | 12:37 PM
beartracks's Avatar
beartracks
do you have anything to start with? Like old factory?
Old Apr 20, 2004 | 12:50 PM
triggerjoe's Avatar
triggerjoe
I do but have not a clue whats wrong with it...
Just bought the truck and the dealer just said NOT WORKIN
Old Apr 20, 2004 | 05:55 PM
brown 4x4's Avatar
brown 4x4
Did your truck come with air or not? If it did, it shouldn't be too hard to get it working, you'll just have to replace what needs it. If the truck didn't come with air, you'll have to find all the parts, plus a bigger hole needs to be cut in the firewall. It would be a lot easier if you had a whole truck to take parts from, but still it's quite a job.
Old Apr 20, 2004 | 11:03 PM
GoldenDually's Avatar
GoldenDually
Is the clutch engaging when you turn the air on high? If not, make sure the clutch wire is hooked up and getting juice. If thats alright, hook up some gauges and see what the suction and discharge readings are. Post them here and maybe I can help you out some more. If I have lost you up to this point then I recommend taking it to a someone that knows a/c's. Parts can get expensive if you don't know how the system works. It is a relatively easy system to learn but you got to have the tools and they are expensive.
Old Apr 21, 2004 | 12:08 AM
Mil1ion's Avatar
Mil1ion
https://www.ford-trucks.com/forums/s...d.php?t=229258
Old Apr 22, 2004 | 10:38 AM
beartracks's Avatar
beartracks
I had mine converted (in the off season) for only $500 at a local shop. It included r124, new compressor, dryer, filter, and hoses. There are several advantages to the conversion not the least of which is a large reduction in vibration/drag.
