1978 - 1996 Big Bronco
Vent Window Seal
Old Apr 20, 2004 | 09:05 AM
Bronco-Red's Avatar
Bronco-Red
Vent Window Seal
MY 92 BRONCO 4X4 NEEDS NEW VENT SEALS ,
DOES ANYONE KNOW IF THEY ARE IDENTICAL
TO THE PICK UP TRUCK (92-96) ?
I tried to order from JC Whitney and it was listed
as 80-96 pickup truck , they said it would not work
BECAUSE IT DONT SAY "BRONCO"
but they look the same , HELP!!!
Old Apr 20, 2004 | 12:35 PM
ctch88's Avatar
ctch88
For $1 you can seal up the vents with a silicon sealer. If you need to use them though, try some duct tape.
Old Apr 20, 2004 | 02:33 PM
greystreak92's Avatar
greystreak92
The F-series and Bronco use just about the same EVERYTHING in the respective model years. 87-91, 92-96 and years prior. The Bronco was built on a really short F-series chassis. Just order the seals for the 92-96 F-series. If they are wrong you can bill ME for them thats how sure I am they will work. Its typical of "parts counter flunkies" who will stadn there and argue that the part won't work because it says its for an F-series and not specifically a Bronco. Autozone's nimrods are really good at that. I actually had an Autozone manager refuse to sell me a headlight switch until I brought the old one in and proved that the Ford part number was the same as the F-series. His response was, "Well, that must be one of the few parts that are interchangable between the Bronco and the F-series trucks". I laughed in his face and have never been back.
