Oil filter wrench
Old 10-13-2002, 01:51 PM
poorboy9us's Avatar
poorboy9us
poorboy9us is offline
Oil filter wrench
OK, my old filter wrench wouldn't fit, so i bought a strap wrench but the damn thing slips.. I have trouble with the filter leaking..
Is a bigger filter wrench available?? Must be, i think!!
Poorboy
Old 10-13-2002, 05:46 PM
Oneof6's Avatar
Oneof6
Oneof6 is offline
Oil filter wrench
You did not say, write, what size your old wrench was. I am assuming that by posting in the Diesel forum you have a PSD. Go to NAPA, they have any size you need, I bought mine there for $11.67 USD. A standard auto filter wrench is to small. If the filter is so tight the strap wrench slips and you have a filter gasket leak also you may have a defective filter gasket, or two gaskets, one from the last oil change that didn't get removed. Don't need to put them on to tight, when the filter gasket contacts go 1.5 turns. Tight enough to not leak, easy to get off the next time.
Old 10-13-2002, 07:53 PM
c_nate's Avatar
c_nate
c_nate is offline
Oil filter wrench
Also had good luck with a clamp type filter wrench. Essentially it resembles a pair of big c-channel pliers with special jaws on the end to grab a filter. Think places like harbor freight and other after market dealers that sell those chinese tools got something similar. Paid $5 for one.
N
Old 10-13-2002, 08:15 PM
gseeders's Avatar
gseeders
gseeders is offline
Oil filter wrench
Hand tight only!
Never have used a filter wrench to put a oil filter on in 26 years! Never had one come off or leak, yet destroyed a few tring to remove them next oil change.
I worked for a Independent repair shop in my early twenties and the boss use a wrench to put a filter on and split the seal! Luckily He caught it before the customer did!
A Good strap wrench from Snap On or Mac will never give you trouble!
over and out
gseeders
Old 10-14-2002, 12:38 PM
bricot's Avatar
bricot
bricot is offline
Oil filter wrench
> Hand tight only!
>trouble!
>over and out
>gseeders
I lived by that until my most recent car. They say right on the filter 7/8 turn, tighten with tool... and 7/8 turn is TIGHT
Old 10-14-2002, 01:30 PM
dale i's Avatar
dale i
dale i is offline
Oil filter wrench
Types of filters (or more appropriately, seals) also make a difference sometimes. When I was using WIX (Napa Gold) they had a flat seal and would always leak. Nothing bad, but a dribble or drop or two. Just enough to leave a line down the filter. When I switched back to Fleetgaurd I noticed they had a wedge type gasket. No leaks. Same with the Baldwin and Donaldson, both have wedge type seals and no leaks.
Old 10-14-2002, 05:45 PM
Dragon Diesel's Avatar
Dragon Diesel
Dragon Diesel is offline
Oil filter wrench
gsxr1300
6.7L Power Stroke Diesel
24
07-27-2014 08:15 PM
Poorboy04
08-16-2013 05:20 PM
Poorboy04
05-29-2013 12:42 PM
Poorboy04
02-27-2013 02:42 AM
star
1999 to 2016 Super Duty
16
02-08-2007 07:53 PM
Quick Reply: Oil filter wrench
