Tune up what a difference
Old Apr 19, 2004 | 08:34 PM
92FordPower's Avatar
92FordPower
I just gave my truck a tune up...Man what a difference...I got new plugs wires cap and rotor air filter breather filter oil filter oil....it is running alot better and smoother now im glad...is there anything else i can do to it or did i pretty much get everything....
Old Apr 19, 2004 | 09:02 PM
jessfactor's Avatar
jessfactor
tranny fluid and differential fluid are good to do. it actually would hurt to do all the fluids. i just did a tune up on mine a few days ago. check your manual to see what is recommended for your current mileage.
Old Apr 19, 2004 | 09:09 PM
ATC_250SX's Avatar
ATC_250SX
Would or wouldent!? even if there not due it cant hurt them, if you do your tranny and its an auto be sure to drain the Tourque Converter, it holds the majority of the fluid.
Old Apr 19, 2004 | 10:12 PM
RLKBOB's Avatar
RLKBOB
Check the timing and adjust if necessary. O2 sensor (if you replace this make sure you disconnect the battery for at least 15 min)
