Light switch issues???
Old Apr 19, 2004 | 06:27 PM
johnrebbb's Avatar
johnrebbb
Howdy all,
I figured I'd start here. It may be the wrong forum for my problem. Hopefully I won't step on any toes.
What I've got going on has got me stumped. My light switch (pull type) has "sweet spots" to get the lights on and then the dash/park lights on. I got a new stich, but the problem persists. What did I miss?
I'm hoping one of you have run into this before and know the cure. It sure is embarassing to hit a bump before daylight (going to work) and have the headlights go out. It can get tricky to hold coffee, steer, and fiddle with the switch.
Any help will be greatly appiciated.
Thanks,
-John R.
Oh, she's a '90 F-150 XLT lariat w/I6.
Old Apr 19, 2004 | 07:44 PM
Egor's Avatar
Egor
I had a 74 Ford truck that I swore the switch was bad in. Turned out to be the dimmer switch. It also had the sweet spots you're talking about.
Old Apr 19, 2004 | 07:45 PM
Fordtech1's Avatar
Fordtech1
Blown fuse in the under hood box.
Old Apr 20, 2004 | 04:17 AM
johnrebbb's Avatar
johnrebbb
I know where the fuses are under the dash. Where are the ones under the hood? Is it one of those deals where I get to chase wires?
-John R.
Old Apr 20, 2004 | 10:43 AM
cmoore101's Avatar
cmoore101
I had the same probelm with a '92F150. Replaced the switch. Same problem. Took it to the dealer. They diagnosed a bad ground wire in about 3 seconds. A ground wire in the rear of the truck had come loose. Hope this helps.
Old Apr 20, 2004 | 04:12 PM
johnrebbb's Avatar
johnrebbb
I'll hopefully be able to run the wires this weekend.
Thanks for the iput fellas.
-John R.
Old Apr 21, 2004 | 08:13 PM
chris1978's Avatar
chris1978
i had the same problem it was a blowen fuse i have an 89 it is under the dash
