1978 - 1996 Big Bronco
Please help Code 334 and 813
Old Apr 19, 2004 | 06:19 PM
Texas Ex's Avatar
Texas Ex
Hello all:
91 Bronco 351W
KOEO code 11
Continuous codes:
334 closed valve position
813 FIPL signal voltage too low
My questions are these:
1) Being that this is a 13 yr old truck, would it just be worthwhile to replace the EGR Valve assembly including a new EVP Sensor to fix the indicated code problem?
2) If I do the above, what other problems could this indicate that may not be fixed with the swap?
3) Where do I start with the 813 code? What am I looking for?
Thanks in advance.
Old Apr 20, 2004 | 01:07 PM
kumabronc's Avatar
kumabronc
You may find this link useful.
http://www.broncodata.com/tech/codes.htm
Sorry but I did not find the 813 code.
