87 f150 front lights
I have noticed when looking at pictures of other people's 87 f150's that the majority of them have chromo accent around the lights - unlike mine. Is that an aftermarket thing? and is it the bulbs that have the trim or is it part of the mounting bracket? I found the accented lights at MrTailLight .com but they are about $100 a piece and come with all the mounting hardware that I don't think I need. Has anyone changed these out, or have a set up that they think looks better then stock?
Haza!
Haza!
They are stock. They came with one of the upgradeable package.
I do believe if you want them you will have to buy the whole set-up, corner lamps, mounting brackets and all.
Unless I'm corrected, the plastic headlight lens is molded into the mounting frame. I'm sure you could probally take them off the mounting hardware but it will be difficult if you don't have the tools to do so.
