i was wondering, i have a 77 f100 2 wd 302 and the dash lights do not work. how ever the blinker indicators stay lit up. i reached to take the cluster out to see if i could replace any bulbs or anything and it crumbled in my hands so i put it back. my question is i found an 80's van with a beautiful instrument cluster in it and it looks the same as mine will this cluster plug right into my harness in the 77 or will i have to make some changes. if its just a couple of changes i can handle that. any help would be greatly appreciated. thanks
i had thought about maybe using after market gauges and putting them in a custom enclosure in the dash. do you have to run all new wires to the new gauges or can some of the wires that go to the gauges i have hook right up to the after market gauges? just another question to try to figure out what i need to do! i did a search on this forum and the question about the cluster has been asked alot and i did get some information those posts as well. but i did not see anything about hooking up aftermarket gauges. Thanks for the replys i need all the help i can get!
