Sponsored by: Auxito
need help! trans or rear end?
Old Apr 18, 2004 | 10:28 PM
samoyed1's Avatar
samoyed1
Question need help! trans or rear end?
just hoping someone can help with a 97 E-150 4.6 problem. The problem i'm having is between about 30 to 45 mph as you start to barely press the gas pedal it almost feels like a bad misfire and will continue until you let off or press the pedal further down. If your in a curve it will vibrate as if you ran off the road on the warning strip. At higher speeds it still feels like it has a slight mis or jumping. No codes present and will still do it with O/D off. It also does the same at low speeds as it does at high speed. Replaced plugs, wires, coil, and throttle position sensor.Any help would be greatly appreiated.
Old Apr 19, 2004 | 07:38 AM
ranger88a's Avatar
ranger88a
You may have a converter clutch chattering. Try servicing the trans and draining the converter.
