1966 - 1977 Early Broncos
dual tank switch problems
Old Apr 18, 2004 | 07:26 PM
nicolds's Avatar
nicolds
Has anyone had problems with their tank selector switch. I have a 69EB and when I try to switch into the aux. tank the motor cuts out like its not getting fuel even though both tanks are full.
Any quick fixes or other ideas would be appreciated.
Old Apr 19, 2004 | 11:52 AM
spartamouse1's Avatar
spartamouse1
aux tank is plastic and pretty easy to take out. so the tank is not rusted gotta have something in the pick up clogging it?? exploritory surgery to fix it right.
Old Apr 23, 2004 | 04:26 PM
RCrawler's Avatar
RCrawler
You are switching the mechanical switch under the seat and not just the dash switch, right?
When I bought my first Bronco, my dad would occasionally drive it to work. He ran it out of fuel a couple of times forgetting that there were 2 switches.
Assuming 1 tank is pulling fuel, check the lines from the switch to the auxillary tank. Maybe check the sending unit itself for damage.
Jason
Old Apr 24, 2004 | 11:59 PM
nicolds's Avatar
nicolds
O.K. I'm an idiot! When I filled the tank after I bought it the fuel bounced off the back of the filler neck and shut the pump off. So what I thought was a full tank turned out to be empty.
I was trying to siphon out the fuel to drop the tank and got nothing but air, So that's how I found out it was empty. I filled it really slow at the pump and it works fine.
Kinda embarassed to admit that was the problem, but I'm glad I found out before I dropped the tank.
