Why Dual Alternaters?
Old Apr 17, 2002 | 11:16 AM
joecamper's Avatar
joecamper
Hi, I am curious as to why a PSD would need dual alternaters. At 130 amps each it seems like one would do the jod for most conditions. Thanks for your input.
Old Apr 17, 2002 | 11:47 AM
proford460's Avatar
proford460
for lots of accessories. usually used on service trucks, ambulances, and conversions (RV)
Old Apr 17, 2002 | 12:32 PM
joecamper's Avatar
joecamper
Ihave an 11.5'slid-in camper with all the Bells & Whistles. Would
this justify a dual alt setup?
Old Apr 17, 2002 | 09:01 PM
SMOTU's Avatar
SMOTU
Two are nice if you RV. If you are buying new, get the extra one. If not, it is very spendy installing the second, better off with hi-performance aftermarket alternator. However, jfwiw, I had both a camper and 5th wheel I used (at different times) with my good old '89 F250 with 460 and single factory alternator and it did just fine. Just like the added security of second alternator.
Old Oct 27, 2002 | 09:39 AM
nitro_rat's Avatar
nitro_rat
Dual alternators are also real nice if you run an on-board welder. In a normal setup, the alternators full capacity is switched from charging the batteries and running your accessories to running the welder. IE your batteries loose their charge after a short period of time welding.
Having the second alternator allows the original one to function as normal and the auxillary one (an aftermarket high capacity unit) to run the welder.
Old Oct 28, 2002 | 02:21 AM
sbinsdca's Avatar
sbinsdca
Awesome!
Now I can get that welder I've been looking at
Bud
Old Oct 28, 2002 | 09:14 AM
Gr8ride's Avatar
Gr8ride
