injection problems with 1987 V6
Old Apr 18, 2004 | 10:42 AM
ccloveraz's Avatar
ccloveraz
1987 bronco II 2.9 v6, it idels irradically and lurches at speed when i am not depressing the throttle, i replaced the map, tps, regulator, O2 sensor, and injectors. i also have removed the egr tube and plugged it. it ran fine for 1100 miles and them started this crap/ any ideas of whats wrong
Old Apr 18, 2004 | 11:42 AM
EPNCSU2006's Avatar
EPNCSU2006
Are there codes stored in the computer?
Old Apr 18, 2004 | 11:49 AM
LxMan1's Avatar
LxMan1
Did you replace the IAC? This is what controls the idle speed. As they age, they can stick and make the idle irratic. It is located on the passenger side of the upper intake manifold.
Old Apr 18, 2004 | 11:53 AM
ccloveraz's Avatar
ccloveraz
i cleaned the iac with carb. cleaner, and havent checked the computer. the engine is kinda modified so i think i will get alot of codes...it did run fine for over 1000 though...i will drop test the iac i a while and post what happens
Big-Hoss
Bronco II
Jul 5, 2011 09:34 PM
nick87ranger
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Feb 27, 2011 07:13 PM
wagon burner
1983 - 2012 Ranger & B-Series
Jan 19, 2007 08:26 AM
George_911
Feb 28, 2003 02:10 PM
