Engine quit
Old Apr 18, 2004 | 06:30 AM
Wgroff_1's Avatar
Wgroff_1
Engine quit
Just bought '03 with 54000 milesw. Water/fule seperator light was on and had rough idle. Drained the seperator several times but light stayed on. Replaced fuel filters yesterday. Truck ran about 1/4 to 1/2 mile and engine quit. Removed cap on upper filter and it was dry.
Any suggestions as to why it is not pumping fuel after changing filters?
Thanks
Old Apr 18, 2004 | 07:25 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
First...........Wgroff_1.......WELCOME to FTE the best Family Ford site on the planet.
Now, to your problem, I have not read of this one before, however there are many very intelligent folks hanging out here. Keep returning and you will probably get some good replies to your problem.
Good luck, I too am interested in this answer.
Old Apr 19, 2004 | 08:25 PM
Fordtech1's Avatar
Fordtech1
Did you try cycling the key a few times to give the electric fuel pump time to fill the filters, did you check the fuse? inertia switch?
Old Apr 20, 2004 | 08:17 AM
IB Tim's Avatar
IB Tim
"inertia switch" OK I am learning....what is this?
Old Apr 20, 2004 | 10:40 PM
Fordtech1's Avatar
Fordtech1
Vehicles with electric fuel pumps use an inertia switch to shut off the pump in an accident. The reset button is located on top of the switch (you push it back down if tripped) and is usually located in the passenger side kick panel. It has a red button on top. Have seen this switch trigger if some heavy feetwork goes on over there, or just tossing in an anvil might trip it.
Old Apr 21, 2004 | 07:44 AM
IB Tim's Avatar
IB Tim
As usual the Thank YOU this stuff is so helpful................now.....
I have a very vivid imagination ……..”if some heavy feet work goes on over there”…………hum
