Air Raid Intake question
Old Apr 18, 2004 | 01:32 AM
Weapon's Avatar
Weapon
Should I purchase the Air Raid Intake system for my 2004 F-150 FX4 SCAB or wait for the K&N. I heard that they are both about the same, performance wise. what do you think
Old Apr 18, 2004 | 08:23 AM
scottb1014's Avatar
scottb1014
I went with Volant, they have an enclosed box for the filter. In MY opinion, I think volant is better
Old Apr 18, 2004 | 10:16 AM
TQB's Avatar
TQB
SCOTT,
Where did you get your Volent at?
Old Apr 18, 2004 | 10:32 AM
scottb1014's Avatar
scottb1014
http://www.proficientperformance.com...xed_truck_ford
There you go.
Old Apr 18, 2004 | 10:35 AM
TQB's Avatar
TQB
Thanks bud.
Did it really improve anything? I have always been skeptical of these for the price. But if they really work then its mine.
Old Apr 18, 2004 | 10:49 AM
F150Texan's Avatar
F150Texan
Originally Posted by TQB
Thanks bud.
I would read this thread for previous discussions on the Volant intakes, and make your own decision.
FTE Volant Thread
Just trying to help where I can. I would call Volant direct first and see what they have to say about issues that have come up.
Old Apr 18, 2004 | 11:01 AM
TQB's Avatar
TQB
Thanks F150TEXAN. I am definatly gonna give them a call before I order that thing.
Old Apr 18, 2004 | 12:36 PM
ctfordguy's Avatar
ctfordguy
I have the Airaid intake and the thing works awesome. Sounds really cool. As for increase in mileage it is still a little early to tell, only have 300 mi so far. I did haul some wood yestarday and filled up before starting. Pulled 2000-2500 lb of wood about 30 miles on the highway, then a load 10 miles on back roads. Normally the gauge hits 3/4 at 95 miles. Gauge read 3/4 and I had 120 miles. I think the thing works and would recommend the airaid.
Old Apr 18, 2004 | 04:30 PM
051F4XF40's Avatar
051F4XF40
I've had a few tanks on mine since I put on the Airaid and I've seen a 2-3 mpg increase.
Old Apr 30, 2004 | 09:02 AM
ieee_raider's Avatar
ieee_raider
Hi y'all,
I was looking at air intakes for the new 5.4L.
Under the hood, the design looks pretty damn good except that it's all plastic.
It gets air straight from the wheel well then makes one 90 degree turn into the filter box then straight into the engine. It looks like a great stock design and I don't see how anything could help it more than maybe three things:
1. Replacement drop in filter.
2. A little less drastic bend.
3. Replace plastic with metal tubing.
Anyone care to educate me on how a replacement kit would really help?
Old Apr 30, 2004 | 02:58 PM
tod8923's Avatar
tod8923
My two cents are the same as 051F4XF40.... The Airaid has an awesome sound and at least 2 mpg more!
Easy to install and very much worth the $300 that I paid.
Old Apr 30, 2004 | 07:42 PM
SoCalSuperCrew's Avatar
SoCalSuperCrew
Factory warranty?
This may be a stupid question, but does installing an intake affect the factory warranty?
Old May 2, 2004 | 10:00 PM
GLankford's Avatar
GLankford
I've had absolutely zero issues with my truck until I installed an Air Raid system. The first time I drove it after I installed it, I could clearly tell that the idle was much lower and that the shift points for the transmission had changed. I got it out on the road and now I have a bad vibration between 1800-2000 rpm's when the thing drops out of overdrive (going up a hill at highway speeds) that never existed before. I don't see how the intake could do this, I'm wondering if unplugging the battery (step 1 in the instructions) somehow dumped some programming in the engine/transmission management system. When it "kicks down" it sounds (and feels) like I'm running over the ridges they put on the side of highway to keep you awake. Scary. Everything was perfect on this truck before this- just 3,200 miles. Any ideas?
Oh by the way, the Air Raid did make my throttle response instantaneous- no hesitation at all! Just hope to figure the vibration issue out....
Old May 3, 2004 | 06:03 AM
scottb1014's Avatar
scottb1014
Yes, it cancels out the warranty on your stock intake, nothing else.
Old May 3, 2004 | 09:30 AM
Robs98f150's Avatar
Robs98f150
Lightbulb 04 intakes
I know k&n has a mandrel bent aluminum tube which I think looks a hell of a lot better than those other intakes but thats just me. As far as the other brands....I heard volant was having problems ....not sure about air raid isnt that a bug spray? I did some research with the K&N and found that on thier web site they specify that Their product will not void your vehicles warranty
Rob
