C6 Trans Temp probe where does it go
Old Apr 18, 2004 | 12:56 AM
tinsmith's Avatar
tinsmith
On my 83 C6, I want to install a trans temp probe. But where do I put it?
Old Apr 18, 2004 | 05:51 AM
shorthair's Avatar
shorthair
when i did my 77 i used the plug in the case just in front of the shifter be careful it will look like 2 plugs but one is an adjuster this will give you the actual trans temp not the pan or the line after the converter.
Old Apr 18, 2004 | 03:13 PM
Birken Vogt's Avatar
Birken Vogt
The pan oil *is* the actual transmission temperature but this pressure port has been measured to not be much different than the pan oil. Apparently the pump doesn't add much heat to the oil. In any case it is a convenient spot.
Birken
Old Apr 18, 2004 | 04:10 PM
tinsmith's Avatar
tinsmith
Ok,
I looked at the left side of the transmission, just in front of the shifter and the netural switch. There is only 1 plug, but it looks like a Band ajuster. And the book shows it to be one too. But there is no other plug, anywhere I can see.
