1978 - 1996 Big Bronco
95 Bronco wont start
Old Apr 17, 2004 | 10:21 PM
3headedboris's Avatar
3headedboris
I have a 95 Bronco that suddenly wont start.
When I turn the key it will crank.
I am wondering if there is an inertia switch on a 95 Bronco.
Any help would be greatly appreciated
Thanks
Old Apr 17, 2004 | 10:36 PM
screwy's Avatar
screwy
Yes, located here. Under the passenger side kick panel, just forward of the door.
Old Apr 19, 2004 | 12:23 PM
3headedboris
Thanks for the inertia tip.
but its not the problem.
here is another question:
when I crank the motor and I am getting no spark and the fuel pump is not powering up. what could that be?
Old Apr 19, 2004 | 12:57 PM
screwy's Avatar
screwy
Does the pump still power up for a second when you first turn the key to run?
Start simple, have you checked all the fuses?
Is the computer getting power?
Old Apr 19, 2004 | 01:07 PM
RLKBOB's Avatar
RLKBOB
No spark is probably the coil but could be other things. The fuel pump should only come on for a couple seconds when you turn the key forward then shut off(then it should stay on while cranking the engine over). Check fuel pressure, if the FP isn't working it could be a bad FP or it could be a bad relay.
