no check engine light
Old Apr 17, 2004 | 06:28 PM
b23's Avatar
b23
Unhappy no check engine light
just failed emmissions testing , 1996 mazda with ford 4cyl 2.83 engine , code p1443 , the check engine light fails to come on with key on test , doesn't come on when running either , any ideas ?
Old Apr 17, 2004 | 11:03 PM
parks911's Avatar
parks911
Check the bulb for that paticular light. Very good possibility that the bulb could be burned out.
Old Apr 18, 2004 | 03:17 AM
andyrew's Avatar
andyrew
if you bought it used, the previous owner or dealer may have disabled it on purpose to sell it easier.
Old Apr 18, 2004 | 06:41 PM
MustangGT221's Avatar
MustangGT221
Moved to appropriate forum, unable to e-mail user.
Old Apr 19, 2004 | 10:07 PM
b23's Avatar
b23
when I bought the truck used the engine light was always on , would clear the codes to pass emmissions , a week or so later the light would reappear and I would repeat the clearing sequence . After a recent tune-up the light went out and would not come on even with key on test , the trouble code p1443 was registered on the states computer and does not relate to the light as far as I can tell , it has more to do with the purge cannester , however I did not fail this particular test . so you can see my delima , anyone with insight please comment I have ten days before registration expires .
Old Apr 20, 2004 | 02:09 PM
Ken00's Avatar
Ken00
I'm thinking you have two problems, I would check the bulb for the no CEL. Check out the link in the tech info post on the EVAP P1443 code.
