Sponsored by: Kumho
Rancho shock install help
Old Apr 16, 2004 | 08:45 PM
garyd's Avatar
garyd
Just got my Rancho RS9000x shocks for my '96 F150. What is the red nylon twist tie for?? I assume I put it around the red boot that goes on the shock. What is a good setting for just regular driving and should the front and the back be set the same.
Old Apr 17, 2004 | 01:21 PM
wiggit's Avatar
wiggit
I run mine almost always at three in the city.I have the compressor and gauges so i change them all the time but most time is spent around 3.Front and back unless you done some suspension work.
Old Apr 17, 2004 | 01:23 PM
wiggit's Avatar
wiggit
Sorry yes around the boots if you need them.
Old Apr 27, 2004 | 07:31 PM
a64armt's Avatar
a64armt
Shocks
I have the cockpit adjust as well. Even at firmer settings, I notice more "bounce" than with the factory Shocks, especially at highway speeds. Do you have the same?
Thanks,
Vincent
Old Apr 27, 2004 | 10:03 PM
wiggit's Avatar
wiggit
No not at all.At 3 or higher my truck rides like a rock with next to no sway or bouncing.
