smoking
Old Apr 16, 2004 | 10:01 AM
evin's Avatar
evin
smoking
I have an 85 ford f150 with a 351 ho there is oil smoke coming out around the pcv.what could this be?the truck sat for a few years could this clear up after driving or is it something serious?
Old Apr 16, 2004 | 12:50 PM
Oscar Meier's Avatar
Oscar Meier
I would guess that you may have a clogged or stuck PCV valve. Also, check the vacuum hose to the valve.
Old Apr 16, 2004 | 08:48 PM
horton-racing's Avatar
horton-racing
Sounds like blowby. Run a compression check. Rings could be worn out or just stuck from sitting so long.
Old Apr 17, 2004 | 07:56 AM
1987LTDmasta's Avatar
1987LTDmasta
run it for a few days and see if it clears. this usually happens to engines that sit for a while.. sometimes it goes away, sometimes it doesnt.
Old Apr 17, 2004 | 04:50 PM
Capone's Avatar
Capone
Try removing the PCV valve cleaning it, if it rattles, then it is most likely in working order....if not, then it could be stuck.
If the smoke coms out in a rythmic fashion, then You have blowby from worn piston rings.
I recommend draining about half a quart of oil....replacing it with marvel mystery oil and running for 20 minutes up and down the rpm range.
then drain and change oil and filter, adding some restore oil additive for high mileage engines will increase compression and help reduce smoking and oil consumption.
Pull some spark plugs, what do they look like? Oily? (worn rings or valve seals/guides), black carbon soot? (fuel mixture too rich), white glazed? (too lean), yellowish to brownish ash deposit (just right)
If oily deposit on the plugs, you may also want to replace the plugs, going up a notch in heat range.
If the truck has been sitting, perhaps while running it you can also spray small bursts of carb cleaner while revving it.
Let us know how it goes.
Cheers
C
Old Apr 18, 2004 | 01:05 PM
evin's Avatar
evin
tHANKS iLL TRY THAT AND LET YOU KNOW
Old Apr 19, 2004 | 04:29 AM
NailZ Lifted F-150's Avatar
NailZ Lifted F-150
if it is the oil seals/rings r they hard to replace or expensive?
Old Apr 19, 2004 | 04:43 PM
spikedog's Avatar
spikedog
<<if it is the oil seals/rings r they hard to replace or expensive?>>
Mainly time-consuming, so if a shop does it they hit you with labor costs.
