78 Duraspark questions
Old Apr 15, 2004 | 09:58 PM
70bluebronco's Avatar
70bluebronco
Took the ignition setup from my 78 F-100 and am using on another model engine.Also using a TFI coil and was having problems with premature spark plug failure due to a bad resistor wire.Checked the coil voltage on a 90 F-150 and I had battery voltage going to coil.I hooked up battery voltage to the TFI coil and it starts and runs real good.Anybody running a setup like this?Any problems?Admin I did read about cross posting but I am running parts from 3 different groups.Thanks for any help..
