Performance upgrade help
Old Apr 15, 2004 | 07:00 PM
chris28's Avatar
chris28
I've got a 63 f100 with a 292 in it and I'm wanting to rebuild the motor. I want to go old school with it so I've decided to go with a 3-2 setup. Here's the question, what other stuff could I do to this engine to get a little more performance out of it? I want to go with a nice lopey cam. My only concern is getting enough gas with the 3-2 setup. Any help is greatly appreciated. Also what's the max I can bore the block? Thanks in advance
Old Apr 15, 2004 | 11:59 PM
My58Ford's Avatar
My58Ford
It's JMO, but you'd be much better off going with a single 4bbl setup than the 3-2's.
3-2's look good sitting on an engine, but if it's performance you're after, the new Blue Thunder intake or even the stock cast iron '57 intake is a much better choice!!
The BEST 3-2 setup won't hold a candle to either of those 4bbl intakes!
Plus you'll spend alot less time tweaking on the 3-2's to keep 'em in sync!
John Mummert at ford-y-block.com has a great selection of performance cams & he's very knowledgeable to talk to, you might want to contact him!
I don't think I'd personally go more than .060 on the bore, but that's just me!
Good luck!
Old Apr 16, 2004 | 07:53 AM
charliemccraney's Avatar
charliemccraney
You can go to 3.86" (312 + .060") bore and still use stock sized pistons. Anything larger than that and you will need custom pistons. To determine the maximum bore that your block can take you should have it sonic tested to see how thick the walls of the cylinders are.
I agree with My58Ford that the 3-2 is not the way to go for performance but they will give it an old school look. Visit John Mummerts site and give him a call. He will be able to help.
You can find a 312 crank and have the mains turned to fit the 292 block. Increase the compression by putting the pistons 0.000"-.010" in the hole (figure this based on the thickness of the head gasket). Cut about .020" off of the heads. Do some porting and polishing. Get some headers. Oh and the ECZ-G heads are the high compression '57 heads. There are some new aluminum heads in development but they are going to be around $3000.00 per set bare.
Old Apr 16, 2004 | 08:18 AM
312's Avatar
312
your block should be c2ae and i wouldn,t go over 060 with this block.they were not as good as the old blocks.as you have been told be sure to sonic test if tou want to go bigger.you should have at least .125 of cylinder thickness left after boring.
Old Apr 16, 2004 | 08:51 AM
chris28's Avatar
chris28
Thanks for the info. I was really wanting to go with the 3-2's but I wasn't to sure. What are yall's thoughts on a 6-2 log intake? Just curious. Thanks again for the advice!
Old Apr 16, 2004 | 01:02 PM
charliemccraney
The 6-2 is not meant for a slightly modified street engine. It is a high RPM, highly modified type of manifold. I still would only use the 4bbl manifold, however. If you intend to drive this on the street on a fairly regular basis, the 6-2 manifold will not be worth it. 3-2s can be hard enough to keep just right 6-2s can be a nightmare. Not to mention that you will probably have to fab up some linkage. 6-2s will look neat on a street vehicle but that is about it. I would go with the blue thunder 4bbl manifold or the stock ECZ-9425-B cast iron manifold, ported and polished, of course. You want to pick parts that work in the same RPM range. Don't get caught up in the bigger is better thinking.
Old Apr 16, 2004 | 06:39 PM
chris28's Avatar
chris28
Anybody know where I could get a set of the 57 heads? I tried ebay but no luck. I know I'm hard headed but I gotta ask one more question about the 3-2 setup. Would they work with a moderate strret engine? It ain't gotta be the best but would it work or would it be too lean on gas? I want the truck to have a little show and a little go! Not a drag racer and not a show winner. just somethin I can cruise in on the weekends and hit the local car gatherings(not really shows just good ole boys showin off their work). Thanks for all the advice!!!!
Old Apr 16, 2004 | 11:56 PM
46 Y-block's Avatar
46 Y-block
Performance upgrade
For my two bits a little "show and go" could be provided by a set of large valve heads, a cam, a pointless ignition, blue thunder intake with four barrel carb, and dual exhaust. Match that to a good trans and a 3.55 or so rear end, and cool out. If you want a bit more go wait for the aluminum heads.
Old Apr 17, 2004 | 12:51 AM
pcmenten's Avatar
pcmenten
Hi, Chris.
I don't know how handy you are, but I think a 3 deuce setup can be made to work fine for the street.
Get a new distributor from the parts store, about $55. I'm going to convert my new distributor to DuraSpark.
Any of the late 50's heads are good; ECZ-C ECZ-G ECZ-B, 5750 and the 5752 heads. Don't use the stock heads.
Get a 312 cam and try to find the 1.54:1 rockers.
Have fun!
Old Apr 17, 2004 | 01:04 PM
chris28's Avatar
chris28
Any idea where I can find those heads? I haven't seen any yet
Old Apr 17, 2004 | 01:42 PM
My58Ford's Avatar
My58Ford
Keep watching Ebay, they pop up all the time!
Old Apr 17, 2004 | 02:44 PM
286merc's Avatar
286merc
The problem with most 3x2 complainers is they havent a clue how to set them up and tune. It is a bit more involved than tossing on any 3 flea market carbs and going for a ride.
The Edelbrock 573 is the best flowing intake and the 553 isnt too bad. The Offy is junk.
Nothing wrong with the Blue Thunder and a fancy new carb if you dont mind blowing $800. And it will still look like any other 4 bbl setup, such as on them Chebbys.
I had my 573 with three carefully rebuilt 94's on and tuned in an afternoon and it is noticably an improvement over the cast iron -B intake and a old rebuilt 475 cfm Autolite. Total cost ~ $250.
My cam is also a Mummert grind; Reds Headers carries Schneider or you can order direct.
Old Apr 17, 2004 | 04:17 PM
chris28's Avatar
chris28
The whole reason I wanted to go ol school with it is because of my dad. This is probably going to be the last car we do together, and I remember when I was little hearing stories of him and his 3-2's. I told him the idea and his eyes lit up! I'll probably go with the 573. Thanks for the info to everyone
Old Apr 28, 2004 | 10:37 PM
My58Ford's Avatar
My58Ford
A set of G heads were just listed on Ebay, if you're still looking!
Item # 2476450772.
Old Apr 29, 2004 | 12:05 AM
Fordication's Avatar
Fordication
Hey there are others looking as well. Ed
