c-4 tranny
Old Apr 15, 2004 | 04:44 PM
saltydog57's Avatar
saltydog57
c-4 tranny
I have a 49 f2 and am putting a 351 clevland with a rear that has 3.73 possi rear and wanted to know if I use a c4 will I need large or small bellhousing and do you think the combo will be good? I will use a 4 link coilover suspension for rear and mustang II with coilover rather than air. also glass tilt front end and glass fenders on rear with a shortened bed.
Thanks, Salty
Old Apr 16, 2004 | 12:40 AM
1952FORD's Avatar
1952FORD
I think you can use either as long as you use the corresponding flywheel , converter and spacer between the engine and transmission. The gears will be a little high for freeway speeds you will be close to 3000 at 65 mph depending on tire size. I like 3.00 3.25 for highway use .
Old Apr 16, 2004 | 03:40 AM
4tl8ford's Avatar
4tl8ford
You may want to check the 351 engine fourm to make sure, I believe that the "Cleveland" blocks used the bigblock bell housing.
Old Apr 16, 2004 | 05:51 AM
4tl8ford's Avatar
4tl8ford
Duh - disreguard the above post, the 351C used the smallblock pattern. The 351M/400 use the bigblock pattern.
I will now take my medications, retire to the basement and play with electricity.
Old Apr 16, 2004 | 04:25 PM
saltydog57's Avatar
saltydog57
Thumbs up Thanks Guys
Thanks alot I don't intend on driving it every day I have my ranger for that I want alot of torque and power and if I can do 65 @ 3000rpm then thats fine gas milage means nothing and besides the clevland doesn't start really strong till your at least at 3 grand and I want to hear it howl through my duel flowmasters! LOL Thanks alot for the info.........Salty
jrockdiddy
Mar 26, 2013 11:39 AM
dragn4door
Jan 9, 2012 03:03 PM
1st_FordTruck
2004 - 2008 F150
Jul 13, 2006 09:59 AM
LNB
Jan 10, 2000 04:34 PM
