need help on electrical fans
Old Apr 15, 2004 | 07:22 AM
greenterror's Avatar
greenterror
Question need help on electrical fans
whats the differance between puller and reversible fans? and wich one is better?
Old Apr 15, 2004 | 09:12 PM
HomerWinzlow's Avatar
HomerWinzlow
I think the puller only pulls air, so if you want to mount it to pull cool outside air into the engine compartment it has to be mounted inside the engine compartment side of the radiator. If you mount it outside under the grille it will pull in air from the engine compartment. Reversible blades would allow you to mount it either inside or outside and get the desired effect by reversing the blade rather than remounting inside or out.
Old Apr 15, 2004 | 09:24 PM
Ultramagdan's Avatar
Ultramagdan
I don't think I would mess with the reversible kit unless I had to. IMHO
