Sponsored by: Auxito
4x4 not working
Old Apr 14, 2004 | 07:18 PM
98 4.6 locked up's Avatar
98 4.6 locked up
4x4 not working
Can somebody out there give me directions on troubleshooting my 4 wheeldrive. It's a 98 4.6 xlt. When I turn the **** on the dash I get no dash indicator and hear nothing. Thanks Jordan
Old Apr 15, 2004 | 12:29 AM
98 4.6 locked up
Hey Racerguy,If your still around could you give me some insight on troubleshooting this? thanks
Old Apr 15, 2004 | 08:32 AM
Racerguy's Avatar
Racerguy
Have you checked all the fuses?
Is the connector at the transfer case plugged in tightly?
Old Apr 15, 2004 | 11:23 AM
98 4.6 locked up
What fuses and or relays should I be checking? And what are the wire connectors for under the drivers side kick panel? One looks a little corroded.
Old Apr 17, 2004 | 12:46 AM
98 4.6 locked up
Checked fuses today. Both were good. Found relays under dash I think. It is a block with 4 or 5 relays in it. Does anybody know which one is for the 4x4. Also checked resistance on switch. All checked OK. What next. HELP!
