I just got my 466 together and was wondering if i could figure out what kind of horsepower and torque this is putting out. It is making 9.5 to 1 compression. Cam has a cam with duration @ .050 Int. 216 Exh. 228 and lift at Int. 518 Exh. 513. It has a Holley 750 double pumper, Weiand stealth intake. And schoenfeld tractor pull headers with 2'' primaries and 4'' collectors. i dont have any exhaust system...just the straight headers. The motor is bored .030 over. If anything else is need let me know...thanks alot in advance
I just run your combo and it(desktop dyno) showed me
451 hp.....5000rpm
526tq......3000rpm
I like that crane powermax cam to by the way good all around cam
The heads are stock D3VE not sure what the exact flow #'s are...but thanks alot for the dyno hookin78 i appreciate it...I too am really happy with the crane cam.
What cam are you using(manufacturer and part/grind number)? If I'm reading right, your cam has more duration and lift on the intake side?? This seems odd for a BBF cam. Also, is it a solid, hydraulic or roller cam?
