is it possible??
Old Apr 14, 2004 | 04:08 PM
gunnabebad's Avatar
gunnabebad
is it possible??
could you put a 63 body on a 70s 4x4 frame with little problems. i want a 4x4 but cant find a swb in the same model. i need an early 70s model so my built 390 will fit.
or could you put a 4x4 drive train under the 63? just some options i am contimplating and would like you opinions.
thanks for the help V/R brian
Old Apr 14, 2004 | 04:18 PM
BobbyFord's Avatar
BobbyFord
Anything's possible, some things just require more patients and more $$. In my opinion if you are looking for a more modern 4X4, I would go with a later model frame and drivetrain. You will be better off with the newer style transfer case, diffs, P/S, And disc brakes.
Old Apr 15, 2004 | 09:44 AM
Mike G's Avatar
Mike G
Also check out the thread by Jetta4 as "63 4x4 conversion"..
Old Apr 15, 2004 | 03:36 PM
gunnabebad's Avatar
gunnabebad
well mine is a swb and 4wds were pretty uncommon in 1/2 ton vertion back in them days. so mine is even that much harder to do. thanks for the help.
