AC Problem
Old Apr 14, 2004 | 12:37 PM
rkersh409's Avatar
rkersh409
AC Problem
I have a 93 F150 with a 302 and automatic. When I bought the truck the compressor was making a loud noise. Took it to an ac man and he said the comp was going out but was still working and blowing cold ac. So I decided to wait till it went out before replacing. Now 8 months later its not blowing cold when stopped but when going down the road its cooling fine. Looked at the condincer metal line that goes to the comp and its got all sorts of oil there at the fitting. My question is it just low on 134a or has the comp finally gone out? Thinking about buying the kit to put more 134a back into it. Till the comp goes out. What do yall think I should do? Thanks!
Old Apr 14, 2004 | 08:06 PM
Ultramagdan's Avatar
Ultramagdan
Sounds like the compressor is toast. Oil everywhere usually means the seal is blown.
Old Apr 14, 2004 | 08:27 PM
HomerWinzlow's Avatar
HomerWinzlow
93 should be R12 unless it has been converted. 94 and up is where they generally split to R134a
