Gear Ratio
Old Nov 14, 2002 | 04:24 AM
Mizzou's Avatar
Mizzou
Gear Ratio
I have a 99 CC Lariat PSD and want to know what gears I am running. What is the easiest way of determining this?
Old Nov 14, 2002 | 10:53 PM
Cope's Avatar
Cope
Gear Ratio
The easiest way is to check the axle code on the door jam. You should then be able to check your owners manual to find out what gears you have. If you don't have an owners manual then either do a search to find a chart to decipher it or post the number and somebody will be able to tell you what it is.
-Cope
97 F-350 PSD ZF 5 Speed 4x4
Old Nov 19, 2002 | 08:16 AM
86Betty's Avatar
86Betty
Gear Ratio
Someone has in fact posted an axle chart on this site...look it up under Tech Articles.
Old Nov 19, 2002 | 01:10 PM
Saigon's Avatar
Saigon
Gear Ratio
