1978 - 1996 Big Bronco
strange vibration..
Old Apr 14, 2004 | 11:05 AM
abigor060's Avatar
abigor060
strange vibration..
its a 90' EB, 351 EFI, and a E40D tranny. my problem is every time i hit the 50-60mph range i get a strange vibration..i cant tell whether its coming from the front or right under my seat (sometimes the front, sometimes under me), and it only happens when my foot is at the very top of the gas pedal either giving it gas of letting off. i noticed it last summer, and its just now starting to irritate me enough to find out whats going on, and it hasnt broke yet (amazingly). ive changed the tranny fluid, filter, etc, had my tired balanced and rotated, and had the braked done...so im hoping it might be something simple like an alignment and not some huge tranny thing i halfta go through..so you guys got any thoughts on what it might be??
Old Apr 14, 2004 | 11:07 AM
peteyg's Avatar
peteyg
U-joints? Is the vibration fast or slow. If it's fast, then for sure u-joints.
Old Apr 14, 2004 | 11:17 AM
abigor060's Avatar
abigor060
its fast..but the u joints dont move at all when i try to wiggle them...(at least i thought that was how u r supposed to be able to tell). is there another way??
Old Apr 14, 2004 | 11:48 AM
peteyg's Avatar
peteyg
You could be getting u-joint binding. That happens when they aren't lubricated regularly, or if the seals fail. They can go bad and still not wiggle. The best way to see if they're binding is to remove the driveshafts and moved the joints by hand. If they are excessively stiff, then that may be your issue. They should move freely in all directions without feeling sloppy.
Is your Bronco lifted? Increased driveline angles can also introduce vibrations.
William Martinez
Feb 23, 2017 11:22 AM
texkwik
Apr 11, 2015 05:07 PM
dg416
1983 - 2012 Ranger & B-Series
Dec 24, 2011 04:30 PM
FSJ-EARL
Jul 20, 2010 10:58 AM
mytruckisjunk
Dec 9, 2009 11:37 PM
