1978 - 1996 Big Bronco
Tire spacers
Old Apr 14, 2004 | 09:26 AM
stupato's Avatar
stupato
Tire spacers
How many of you use them? Pros? Cons? Opinions?
Old Apr 14, 2004 | 11:38 AM
Stokes's Avatar
Stokes
lol your wheel bearings will never forgive you! other than that, shur why not use them, i think its a much wiser idea to just get a better offset rim
Old Apr 14, 2004 | 05:00 PM
WhëëlMå1's Avatar
WhëëlMå1
They are a cheap and unstable fix. They might be ok on a light car, that sees only pavement, but do not think for a second that they will stand up to what a Bronco can throw at it. Like jojo mentioned, you *should* just get the proper backspaced/offset rims.
Rich
Old Apr 14, 2004 | 08:12 PM
stupato's Avatar
stupato
thanks...got mixed feelings from other sites.
Old Apr 15, 2004 | 05:49 AM
RTM's Avatar
RTM
There are two kinds of wheel spacers. One is just a spacer and the other spacer bolts to the rotor and then has a different set of studs for your wheel. They say the bolt on spacers are the best if you need to run them and I have read many times that anything over 1/4 inch is very unsafe and this is on a car not a truck whick is much heavier.
I myself would never install a wheel spacer on a truck. The cost or the danger of something going wrong far out weighs the cost of the correct wheels.
Old Apr 15, 2004 | 07:20 PM
entomber's Avatar
entomber
What is the cost on an offset wheel?
Old Apr 15, 2004 | 08:10 PM
Stokes's Avatar
Stokes
preaty much any aftermarket wheel has a greater off set than stock, they normally will list what they are, the widest you can safely go is 2.5Backspace on a 10" or wider rim.
Old Apr 15, 2004 | 08:14 PM
entomber's Avatar
entomber
Hmmmm okay down the road.. I'll look into something. That's 5 rims you gotta buy for a Bronco (the spare)
