removing 205 transfer case???
Old Apr 13, 2004 | 09:18 PM
my4604x4's Avatar
my4604x4
Hello,
I am trying to remove my 205 transfer from my c-6 trans in a 78 Bronco.
I did it before w/ my 79 f-150, but can't seem to get it out of the bronco.
I removed all the bolts from the adapter that hooks the c-6 to the 205 & rechecked to make sure I got them all. Bracket is off & driveshafts off & tried to pry them apart & jar it my dropping the jack fast, but won't let go. Am I missing something?
Many thanks
Randy
Old Apr 13, 2004 | 11:32 PM
ivanribic's Avatar
ivanribic
When you say "bracket is off" you mean you unbolted the adapter from the crossmember? I had a little difficulty getting mine out too, I had to loosen the bolts to the crossmember to get a little more slack in there. then I put a jack under the tail end of the tranny. If your Bronco is anything like my truck there is no crossmember on the back of the tranny. All of its weight is supported by the crossmember under the t-case. When I gave my tranny a little lift it relieved the tension and the 205 slid right off. Also, if you can get to all the bolts, it may be easier to unbolt the adapter from the t-case rather than from the tranny.
Hope this helps some.
Old Apr 14, 2004 | 12:13 AM
Mil1ion's Avatar
Mil1ion
https://www.ford-trucks.com/forums/s...d.php?t=229258
Old Apr 14, 2004 | 05:36 AM
my4604x4's Avatar
my4604x4
The bracket is the one off on the drivers side that bolts to the case and then on to the frame. I have the trans. mount bolts off to the crossmember.
I am trying to remove the transfer from the adapter is that right or do I need to take the adapter w/ the transfer case or it may not matter????
Thanks
Old Apr 14, 2004 | 07:01 PM
my4604x4's Avatar
my4604x4
Thumbs up
I guess I did everything right. I left it sit overnite with all the bolts off and got home from work and the gap between the trans. & the transfer case had grown. Set my roller box under the transfer and alittle pry bar action and ITS OUT!!!!!!!!
Thanks For the help!!!
