Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
oil in throttle body
Old 03-23-2004, 08:37 AM
03Harley's Avatar
03Harley
03Harley is offline
Angry oil in throttle body
Anyone have a supercharged 5.4 have any problems with oil. like always having to add oil and oil all over inside throttle body?
Old 03-23-2004, 05:42 PM
ltrripp11's Avatar
ltrripp11
ltrripp11 is offline
yes, i have a 2001 lightning that does the same. i dont have all the answers on it but apparently its a design flaw with the p.c.v.system causing this under boost conditions. i saw a kit that allegedly rectifies this on e-bay under parts and explains the situation somewhat!!! im reluctant to pop for it though and sort of looked at it as a sales pitch without any real proof it works behind it. good luck.
Old 03-27-2004, 10:33 AM
03Harley's Avatar
03Harley
03Harley is offline
I just had a frind of mine (hes a mechanic ) take my intercooler out and clean it. What a oil coated nightmare oil coated everything he even said he couldnt beleive what a bad design by ford. I also installed a oil seperator from razors edge and after only 30 miles I had about a teaspoon of oil in the bottom. For $50.00 I think its a good investment.
Old 03-27-2004, 11:28 AM
Talyn's Avatar
Talyn
Talyn is offline
sounds like a great idea harley. =)
Old 03-27-2004, 12:54 PM
ltrripp11's Avatar
ltrripp11
harley, where exactly did you place the oil seperator?? between pcv valve and hose to intake i assume?? also where is razors edge??. thanks.
Old 04-17-2004, 12:58 AM
03HDtrucker's Avatar
03HDtrucker
03HDtrucker is offline
Thumbs up Oil separator
03Harley, does Razors Edge have a website? I'd like to get one of these for my 03 HD.
Old 04-17-2004, 01:07 PM
2002BLGT's Avatar
2002BLGT
2002BLGT is offline
just so you guys know , if oil gets on your mass air meters if you are having this problem , it will cause your trucks to run LEAN which is bad , make sure to clean it out with brake cleaner and fix the pcv issue , or install breathers in the valve covers , www.modularfordpowerhose.com , this guy has had experience with this problem and has access to some nice breathers for the valve covers .
Old 04-18-2004, 01:08 PM
mitch5170's Avatar
mitch5170
mitch5170 is offline
From what I know the problem is caused by going into boost then releasing the throttle quickly, causing the intake to suck oil thru the pcv system. You can purchase a oil seperator system from several sources. Go to NHTOC.com and do a search for this same topic, you will a truck load of info!
Oh...and I dont believe its as easy as adding valve cover breathers...unless you have your pcm reprogrammed Im pretty sure it will set a code.
Heres some links to vendors that sell the kit...
http://www.lightningforceperformance.com/home.html
http://www.razorsedgemotorsports.com/
http://www.johnnylightningperf.com/
http://www.teamjdm.com/
Old 04-21-2004, 09:10 PM
03HDtrucker
breathers
I wrote an email to Lightning Enterprise regarding breathers and this is the reply I got:
Personally I have tried it both ways...only no one seems to ever know what
figures to use when allowing for the corrected air entering the open
breather and into the air / fuel ratio.
I have dyno tested with the breather and found that without correcting for
the supposed added air that enters the equation that there is a small amount
of leaning out through mid range RPM but that it equalizes by 4500 - 5000
and doesn't seem to cause detionation during the lean period what so ever...
No I would not reprogram my PCM...besides what figures would you use anyway
as I have no knowledge of any being comprised...
So what are your thoughts on this?
Old 04-25-2004, 08:08 PM
03HDtrucker
so what do you think?
Jr_f150
2009 - 2014 F150
04-21-2016 01:31 PM
ZachManXLT
1997 - 2003 F150
02-04-2016 10:34 PM
Pele
06-13-2015 01:43 AM
jkinghorn6.0
Modular V8 (4.6L, 5.4L)
04-07-2014 08:46 PM
ecolandscaping17
1999 to 2016 Super Duty
02-02-2014 07:18 AM
Quick Reply: oil in throttle body
