6 speed versus automatic
Old Nov 27, 2002 | 09:50 AM
jmbadavis's Avatar
jmbadavis
My husband and I are looking at buying a 1999 or 2000 F250 diesel. We have heard that with an automatic on a diesel that there are often times problems with the transmissions. There seems to be too much power with the diesel, which causes problems with an automtic. What are the opinions with buying a 6 speed versus an automatic? We will be using this truck to primarily pull a fifth wheel 4-horse trailer, so maybe the 6 speed would be a better use for us.
Old Nov 27, 2002 | 10:04 AM
WXboy's Avatar
WXboy
We can use Dodge as an example here.
The Cummins Turbo Diesel comes in two versions: a regular output model and a "high output" model. The "high output" diesel can ONLY be ordered with the 6-speed manual transmission.
That should answer your question. Automatics have advantages too, and in most vehicles they come with higher towing ratings. But for some reason, diesel powered trucks seem to be stronger with the manual transmission. Of course, this will all change now with the new TorqShift Automatic, but if you are looking at 2000 models, I'd stick with the 6-speed if I were you. Especially if you plan to tow a lot. You can use the 6-speed to control your speed better.
:-X12
Old Nov 28, 2002 | 10:09 AM
The Diesel Dude's Avatar
The Diesel Dude
What WXboy said is true but this new Ford Powertorque automatic transmission was developed specifically for towing. The computer senses the fact that you are towing a load and automatically adjusts the shift points to accomodate the fact that you are towing. Then when you unhook and are just running the truck with no load, it automatically reverts back to normal shifting. If I were you I'd take a good look at this new transmission package.
Old Nov 28, 2002 | 10:47 AM
jschira's Avatar
jschira
I towed with an automatic and a stick. With the automatic, you have a fluid coupling between you and the load. This seems to soften the jerking from the trailer. When I towed with the stick, I felt every tug of the trailer.
Just my impression. No scientific facts.
Old Nov 28, 2002 | 12:25 PM
Gutlassf250's Avatar
Gutlassf250
